Hi - How do I redownload a purchased design into GS 7? Thanks! Pete
If you have the purchased design installed in GarageSale 6 on the same Mac, your design should automatically carry over. However, there is one caveat: Purchased designs only work if the licensee name in the current version of GarageSale matches the licensee at the time the design was purchased.
So, you have to make sure that you are running GS 7 with a licensed in place. If that’s the case, and the design is still not showing up, choose “Help” menu > “Open Library” folder. Check that the folder “DesginTemplates” shows your custom designs.
Thanks Ilja - I haven’t purchased it yet, that’s what the problem was. Any word yet on using GarageSale with other selling platforms?
One we got the 7.0 final out, we’ll start adding additional platforms. Right now it seems we’ll start with Etsy, as it doesn’t require a shop subscription to use third-party tools, like Amazon does.
That’s awesome! What other platforms are under consideration?
I thing only Etsy and Amazon got significant requests so far. If you have something else on your mind, please let us know.
