GS seems to keep randomly re-setting my quantity to zero. Large sections suddenly lose that setting, then when re-listing or revising, it won’t do it because of no quantity (thank you for putting that quantity-blocking feature though. Very useful but only if it is actually out of stock.)
Fortunately I have just a few multiple items listings, but every time they expired, the relisting sets quantity to zero and so they don’t relist at all. It’s months I don’t list multiple listings so I don’t know if this problem is only related to those listings you created with a beta (or very old) version of if it still exists also for newly created ones… anyway, I have those 5-6 listings that every time they expire I have to manually change the quantity… I told about this months ago, I don’t know where that listings went…
GarageSale handles items with a quantity of 0 the same way as it would when it has a quantity of 1. But you use auto-relist, right? So the issue is that no relist will be triggered after the listing ends?
I am having a problem with variation listings resetting to zero quantities. Last week when my listings with variations tried to auto-restart it said they can’t be re-started because I don’t have enough inventory. I looked and for some reason the quantities had all reset to zero! I manually changed all of the quantities back to their correct quantities and restarted them. Today they were going to auto-restart again but the same thing happened: all of the quantities, only on listings that use variations, were reset to zero so they wouldn’t re-start!
This just started happening about a week ago. I think I had force quitted GarageSale a few times shortly before this problem started. Maybe the force quitting messed something up on my system or database?
