Hi. I am having to go through my GS listings and compare them to what I have listed on another platform. Is there a way to mark those which have been checked?
I had started by simply putting a symbol at the start the title then realized I would then have to go back and erase that symbol when I needed to re-list (as Find and Replace does not work, that is a HUGE task with 20,000 listings).
Is there any kind of flagging or colour coding system that I have missed?
