Hi, How do I get back my paid designs after I lost everything from a dual backup (TimeCapsule) crash, then MacBook Pro HDD crash within a day of each other>
Hi Ray,
are you already using GarageSale 7?
If so open the “Design Template” window from the Window menu and hit the cart button there.
Thanks, but now how to I find my transaction id?
Hi Ray,
you find it in the confirmation mail that you got after purchasing the design.
However, you can request your transaction ID (and GarageSale license) at any time in the “Lost Licenses” section on our website:
http://www.iwascoding.com/Contact/index.php
Hi Kristian, I just tried the, got a whole lot of GS licenses from 4, 5, 6 and 7 and 2 emails without any major information but had a funny Subject: Your high_priced License
Being 2 of them is seems to line up with the 2 Deigns I purchased…
There is no transaction id in the email:
!PLEASE PRINT THIS MESSAGE AND KEEP IT AT A SAFE PLACE!
Dear ,
thank you for obtaining a license for high_priced.
This message contains your personal serial number for high_priced.
Registration Information:
Name:
Code:
If you have trouble registering high_priced or you are not sure what to do, follow the instructions below:
To register your current version of high_priced:
If you do not already have installed, download it from
https://www.iwascoding.com/ -
Double click on the program icon to open and start the program.
From the ‘’ menu on the left side select “Enter License Code…”.
Enter “” into the “User name:” field
Enter the following numbers into the “Unlock code” field:
Click the “OK” button.
The Registration Dialog should then disappear and you should see your
name in the ‘About Window’ of as the registered owner.
In case the registration dialog should NOT disappear:
- Make sure you have your name spelled exactly as displayed in step 4. above.
Copy your name from your e-mail client and paste it into . - Make sure you haven’t copied the quote (") - signs.
- Make sure you have entered the right Registration Number.
You can copy this one too and paste it into .
If the serial number still doesn’t work, don’t hesitate to notify us.
Thanks for again supporting ! Be sure to check out the webpage for updates and hints:
Regards,
iwascoding.com Crew
iwascoding GmbH
Weserstr 18, 10247 Berlin
HRB 97269 B Amtsgericht Berlin-Charlottenburg
Geschäftsführer: Paul Hecker, Ilja Iwas
Hmm, I see, please contact me through the GarageSale support directly:
