Hello how can I renew my scubscription? Payment did not go thru, when I try to renew in iwascoding store I get massage a subscription already exists for this account.
the subscription will renew itself automatically. If it currently is in the paid state you do not have to do anything.
If you want to change the payment method you can do that from within GarageSale. In the Pro Preferences, there is a blue link “Manage Payment Method” on the left side. You should be send to the website of our payment provider where you can change these options.
No there is no option for manage payment method
I think my subscription is cancelled beccause my payment didnt go thru
only given option to create account and i already have an account i can’t login either I think because my account has been cancelled. my password i use to login doesn’t work
Can you please contact our support directly through email so I can send you further instructions?:
As far as I can see your payment finally went through and your GarageSale Pro account is active again. ![]()
You might want to check if you have already defined the correct credit card as the “default” payment method. You can do this by clicking on “Manage Payment Method” in the GarageSale preferences > Pro.
