Return policy attributes not valid"
Hello,
I hope someone can help me sorting out this pretty strange error. When I upload items to ebay UK, I get the message “Return policy attributes not valid on this site”. Of course I read all threads of people having similar problems, unfortunately - this could not give me any hint because my problem seems to be slightly different.
I have absolutely nothing written im my “additional return info box”. I accept 30 days returns, seller pays for return (and no restocking fee, there is no box I could tick for this anyway). So, I am rather confused. I read all ebay UK changes, but again - no input what might be wrong. When I try to change the uploaded item description (it is possible to upload!), I can not tick the box “international returns accepted” directly on the ebay site. Domestic returns accepted" seems to be ticked automatically. I am puzzled :frowning: . Any hint would be great, many thanks in advance!
Best regards,
Sabine.
This one has hit me today as well (earlier threads seem to predate this).
I have tried removing the text from the return policy box - that didn’t work
I then just de-selected the tick box that says “returns accepted”; it now looks like I don’t accept returns (but in my line of sales it can be years between requests). The GS launch scheduler accepted these for listing without any warning triangles or error messages. I have still to test whether they will go through the listing process but I suspect the return policies are being imposed by ebay anyway.
Then we are already two!
I can upload (with warning), but when I go directly into the listing on ebay (in order to check or change), I can’t do anything - it looks like I only accept domestic returns. Which is not true.
Hi Sabine,
is it a yellow warning or a red error that you get from eBay? Warnings can be ignored and you can start the listingy anyway, that’s why I am asking.
If it’s an error message from eBay, could you export one of the listings in question using GarageSale’s export function (File menu > Export Listings) and post it here or send it to me (to the support) so I can have a closer look at it?
https://www.iwascoding.com/GarageSale/Support.html
Hi Kristian,
Many thanks for your quick reply! It’s a yellow warning, please see snapshot.
Also, I tried to exported the listing, but can’t upload it here because I get an error message “Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, garagesale, txt, pdf, gslisting, zip, mov)”. Even though the ending of the exported listing is gslisting. So, I uploaded a link to the item, hope this helps. Many thanks in advance!
Best regards,
Sabine.
https://www.ebay.de/itm/312175504045
Thank you for the screenshot. It’s strange that eBay returns that warning but you can simply ignore it. You can also right-click on the warning message and select “ignore”. This way GarageSale will suppress this warning in future.
I am still interested to have a look at the return settings in the GarageSale listing file. Could you try to compress (zip) it before trying to post it here?
Hi Kristin,
sure - here comes a zip-version!
Best regards,
Sabine
Fancy 70s art glass vase by HIRSCHBERG pop art design Germany YELLOW.gslisting.zip (373.4 KB)
Ooops, sorry - of course I meant Kristian!
Thank you.
You’re offering a 14 days return option. Due to eBay it seems you have to offer a 30 or 60 days return option.
More info about these changes:
That’s right, but - I am not Top Rated Plus (so, 30 days are not required and no free return either). I tried it with 30 days and with 14 day, the result is always the same - and the error message is always the same. Yesterday, I spent the whole evening with this problem and googled through the ebay.com and ebay.uk communities. Unfortunately, without any hint :frowning:
I see. I also find it strange that eBay returns that warning message. However, for now it seems you need to ignore it.
You can right-click on the warning message and select “ignore”. This way GarageSale will suppress this warning in future.
Many thanks for your reply, Kristian. Hm…actually, it’s not really satisfying that all I can do right now is simply ignoring the warning. Anyway, I would have preferred a solution, of course (and I am still worried it might have consequences, you can never know when selling on ebay).
