I am getting a red warning and “Return Policy Value is not Valid” with “Please specify a Valid Return Policy Below”.
I am in the UK and trying to list in the Collectables/Art/Antiques category which does allow a 14 day return policy. I have tried changing the returns policy to 30 days but that does not work either. I have found the only way the listing will be uploaded is if I set the Returns Policy to also include International Returns. That means I then need to go to the eBay website and remove the international returns once it has gone live.
eBay made changes to the returns option recently, e.g. using a return description is no longer possible. Maybe you’re still using this or another deprecated return option.
Please make sure you have the latest version of GarageSale 7 (version 7.0.16) installed which should cover all changes.
If you’re using a business profile for your returns you need to update it on the eBay website directly and then (in GarageSale) select “Update Profiles” from the Profile menu in the return options.
