I am using GS 7.0.10 and i am selecting multiple auctions and then select auction repair picture links (actually i am using the german version) . Even though i selected multiple items it will only fix the first an then stop. Is there a way to fix multiple listings? Or am i doing something wrong?
That’s a bit tricky. You have to make sure that you select them all in overview mode, too. Please see the help here:
https://manual.iwascoding.com/gs7/en/Listings_Section-Bulk_Editing.html
