Revise selected properties only option does not update weight
When you select Revise Listing and select the “Revise selected properties only” option then chose the property “Shipping Options”, the listing weight does not get revised (shipping price and method does get updated).
Same with package dimensions. This is a known bug that has been fixed and will be made available when version 9.9 comes out. I reported it to them a while back and they quickly fixed it. You can try the beta out, or do a “revise full listing” which is what I do to get around this issue.
As @vjl already mentioned this will be fixed in the upcoming GarageSale 9.9. If you don’t want to wait you can already download a beta version here:
