moving from GS6 to GS7 with existing active listings is total pain
just imported my listings. made all changes, spent several hours just to find that i can’t revise them !
GS7 know that this listings are active. so why revise option is not available?
GS6 approach to this was dumb but it works fine (connect template with auction through drag-n-drop and all done).
ok, looks like i found the problem.
when i import listings and then delete them (to deleted listings folder) and repeat import procedure - newly imported listings counted as not active. and those deleted - active and revisable.
not very intuitive behavior i think.
paul
June 20, 2016, 6:33am
#3
how do you import your listings? From eBay or from a file?
You should empty the trash. We can not import the same listing as active twice. That is more confusing than everything else I think…
importing from file not working at all. i talked to Ilija previously. He knows my situation.
yes, importing listing as active twice is bad idea. but i think GS had to notice user in some way.
