Saving a Draft Listing?
I need to be able to draft a listing and save it for future use and then move on to another etc. I see no way to Save a draft = or any notation that any drafting is automatically saved in GarageSale 7. Can I save a draft?
All your work is saved automatically.
Simply create a listings and keep it as a “draft”. You can duplicate it and work on the duplicates.
Another way is to create a “master listing” or setup default settings in the GarageSale preferences > eBay > New Listings.
Please see the help here:
https://manual.iwascoding.com/gs7/en/GarageSale_Preferences-eBay.html
