Saving GS Templates
I regularly back my Mac up but is there also a way of making sure I save all my templates manually? Which folder in the user Library contains them that I can manually save to a hard drive? I just would like to have that safety back up rather than losing such a lot of work. Thanks in advance
The only way to save your listings manually is to use GarageSale’s “Export Listing” command from the File menu.
https://manual.iwascoding.com/gs8/en/Listings_Section-Exporting_Listings.html
You might want to hold down the option/alt key while invoking the “Export Listings” command.
This way you export each selected listing to a separate file.
