Hi all, Haven’t used GS in a couple of months, went to open and got message that it’s damaged and to trash it. I know the containers are in certain folders etc. Can you direct me how to reinstall this monster…thank you so much!
You most likely just need to put the GarageSale application into the trash. If done, download a fresh copy from the GarageSale website:
I don’t think you need to delete your actual GarageSale database.
