Hi Nigel,
could you post a screenshot from your “About GarageSale” panel, too?
Are there maybe tools installed on your system which could block the network? (Kaspersky, LittleSnitch, MacKeeper, HandsOff, cisco anyconnect, GlimmerBlocker or any other AdBlocker)
Hi Kristian,
The only AdBlocker I have is on Firefox. However, I just disabled it and still get the same Activation Failed message from GS.
Regards, Nigel.
Hi Nigel,
the GTC transaction ID doesn’t work because your GarageSale is not registered under the correct name.
I’ll reply to your support mail and give you further instructions there.
Okay - hope you can fix it soon,
Nigel.
Hi Nigel,
that is nothing that we can fix. You have to fix it by inserting the correct license code and I’d like to send you instructions. However, it seems that you still don’t receive my support mails
Please check your spam folder once again or use another email to contact us.
Kristian,
Still no go with GTC. I’ve tried everything you suggested.
What can we do?
Nigel.
