It does not work for me
How do you search? Do you search for the t whole tracking number? Did you select to search for the tracking number in the search popup?
In order section, I typed the number on the top right white field, then tracking number… but no results. However that number was correct…
just upgraded. same for me
just found out that the search index is not updated for old transaction ID. So the search will only work for tracking numbers that are entered (or re-entered) in the current version.
Please see this post for instructions on who to enabled tracking number searching for existing orders:
