This started yesterday - when I search, I get results in the left hand LISTINGS window. I used to highlight the one I wanted, and when I deleted my text in the search window, the item would be showing in the LISTINGS window, still highlighted. Now it’s not doing that. I saw that David had this issue a while back, but didn’t see a resolution. Any ideas? Thanks!
I had that issue too, quite annoying because that means it is corrupted. I recall that it fixed launching a debug feature, but I don’t remember exactly which one. I just advice you to keep a manual backup of GS folder in library before using debug feature.
Could be - just had another weird thing happen. Ended a listing, went to resist it, and got the old SECURITY VIOLATION HTTP warning, though I know there was no HTTP address in the listing. So I made a new listing, copied everything over, then tried to verify - same problem. So I decided to take it apart to see where the problem was. First thing, I removed the photos, and BINGO it verified. Added the first photo - VERIFIED. Added the second photo - NO GOOD! So I opened all the photos and recorded them and renamed them. VERIFIED! Any thoughts? Database corruption?
I rebuild my database every couple of weeks now. Doesn’t take long and it certainly helps. In another post I made mention that removing ghost listings made a massive improvement to GS response time. You may have these and not know it.
