The send icon is missing from the menu bar of the contact buyer message panel. Cannot therefore send messages from within GS.
GS 8.2.1 (1251)
Mac OS 11.1 Beta (20C5048k)
GS 8.2.1 (1251)
Could you post a screenshot so we can see what you see?
Are you saying that the button with the paper plane is missing in the toolbar? I marked it in the screenshot attached.
Yes, the âpaper planeâ icon is indeed missing.
What version of MacOS are you using?
Still MacOS Big Sur, Version 11.1 Beta (20C5048k)
Sounds like it might be a good time to âupdateâ the Toolbar???
add Toolbar icons for Verify, Revise, Relist, Stop.
add âCustomize Toolbarâ command to rearrange and move icons and Search box around.
add âicon text/names/titlesâ command like GS 6 had: âIcon and Textâ, âIcon Onlyâ, and âText Onlyâ.
How shut i do this?
OOPS!!
I meant those as feature request changes for the development team.
Sounds like the current toolbar is not functioning correctly under macOS Big SurâŚ
Oh, ok. But u ve got it reply to me.
Could you (or anybody else who is running into the missing âSendâ-icon issue give this version a try:
https://downloads.iwascoding.com/downloads/GarageSale_8.3b4.dmg
Is the Send toolbar item back?
version 8.2.1 never lost it
can you make a screenshot of the whole toolbar? Is the button visible on the right side?
The button is not visible anywhere in the toolbar or panel, irrespective of panel width.
HTH, âjohnâ
Thatâs unfortunate, as we still cannot reproduce the issue on Big Sur here.
Can you run the line below in your Terminal, and then send us the contents of your clipboard, which contains your GarageSale preferences.
Please use the private message feature on this site (click on my avatar icon) or send it to garagesale@iwascoding.com referring to this thread, as the preferences may contain personal information.
defaults read com.iwascoding.garagesale8 | pbcopy
??? No Terminal command shownâŚ
Tried â11.1 Beta (20C5048k)â ???
Intel Mac or M1???
Thanks. Forgot the add the actual terminal command.
We could not reproduce on either Intel or Apple Silicon on current public Big Sur.
I tweaked the way the toolbar for the âSend Messageâ window is setup. Maybe this cures the problem. Can you please give this version another try:
https://downloads.iwascoding.com/downloads/GarageSale_8.3b5.dmg
