I have purchased a pro design. Now I want to know how I can edit that design and save it as a template to use it on my new listings as well as the imported listings from eBay?
Thanks
Thanks
Sorry, the source code of designs from the Design Store can’t be accessed or changed.
However, you can simply select it in GarageSale’s design browser so there#s no need to create a “template” of it. Also, you can define it as the default design in the GarageSale preferences > eBay > New listing.
