I am creating a template where I pull item attributes from the listing specifics (as per “Creating Your Own Listing Designs” in the user manual). I would like to have the template pull information from the condition details (i.e., seller notes") as well. Is it possible to do this?
Here is an example script that looks for an item specific called “Material”, and changes the selected listing name to include its value
tell application "GarageSale"
repeat with specific in item specifics of theListing
if the specific name of specific is "Material" then
set materialName to item 1 of (get values of specific)
set listingName to "my listing title " & materialName
set the title of theListing to listingName
end if
end repeat
end repeat
end tell
Thank you. I will take a look at the code and see what I can do.
The autogeneration of listing content based on item specifics is a huge time saver by itself. As a workaround, I was considering just creating a draft title in the body of the listing and then copying and pasting it into the title section.
