Would it be possible to add the Smart Folder Attribute ‘Uses a Varition’?
Thanks, Steve
Thanks, Steve
That’s not possible with the current version. I added your request to our ToDo list.
Another Smart Folder option I would like to see is “Item located in folder (group)”
Yes. And even better… “Item NOT located in folder (group)”.
