Smart Group INSTANT shut down minefield
I have one smart group folder that instantly shuts down Garage sale if I get anywhere close to it. It won’t allow me to make any changes to it because as soon as my cursor close to it, it shuts the program down. I did create a new smart group folder exactly the same with a new name after quite a few shut downs and the new smart group folder works fine. Any ideas? The original was created on a different computer before sync was enabled and that folder still works on the first computer.
do you send the crash report when GarageSale asks you after it started up again? Can you send me the Crash ID from the About dialog?
Certainly. Where do I get the crash ID and where is the About dialog?
it is 40000 characters. what do you need?
dumb info deleted by clueless user
You find the Crash ID in GarageSale’s “About” window. Just select “About GarageSale” from the “GarageSale” menu!
Ok, I need my glasses,….
Crash ID: 03044c6f40ca5ebca67dc87af2e8aa49
GS still shut down when regular clicking but I was able to right click and delete the smart group and finally got rid of it. The problem is solved.
