Using GarageSale Version 7.0.14b2 (830), macOS Version 10.12.6 (16G1212)
From the GarageSale Help:
To easily jump to the original of an item displayed in a smart group, right-click on it and select “Reveal Original”.
When selecting this command from the Contextual Menu, it DOES “open” the Original item’s parent group folder, but it DOES NOT “select” the Original Item.
It should also scroll the list so the Original item, which is now selected, is visible in the list.
OOPS! Here is some more Console Output. Full text in .txt file. I selected the “Reveal Original” command 3 or 4 times on different listings within different Smart Groups.
Restart GarageSale and invoke the reveal command again.
The logging I’m looking for should look similar to this:
2018-03-04 20:26:58.133 GarageSale[14237:5538580] selectNonSmartGroupItems: group title is
2018-03-04 20:26:58.133 GarageSale[14237:5538580] expandGroupRecursively: called for group 2014-08
2018-03-04 20:26:58.133 GarageSale[14237:5538580] expandGroupRecursively: groupRow is 10565, returning
