Hi. I have a Smart Group created where unsold items that have finished listing are moved to a folder. The criteria are “All - Status - Is - Ended Unsucessfully” .Mostly this works but I have a bunch of finished listings that remain in my Live Listing smart folder, even though they are marked as Finished. I can’t figure out why they are not moved to the Unsold folder.
I’ve attached a screen shot so you can see how live and finished listings are appearing on the same page as once.
You should be able to drag a screenshot image file directly into the reply box on this page. Maybe this works. If not, please send the screenshot with a link to this thread to garagesale@iwascoding.com. Thanks.
