I have tried to isolate the reason by deleting the description or changing fields and attributes but I cannot determine why this is happening. Most listings export fine, this happens only to a few listings.
Can you export one of the listings that you can’t export to CSV by using the regular “Export listing…” command from GarageSale’s File menu, zip that exported listing, and then post it here?
After deleting the item attributes it works. Still strange.
GarageSale chokes on the empty value field for the “Brand” attribute. Will be fixed in the next release.
When I filled in the Brand attribute it exported properly. Glad to hear it will be fixed.
Thank you,
Bob
