Hi Guys
Noticed today that “Stop Listing” is not stopping the listings in my GS8.
Tried 4 or 5 times today in different areas and all have failed.
What can I do to debug for you?
Hi Guys
What exactly happens if you select “Stop Listings…”. Does the “Are you sure you want to end the listing…” dialogue appear?
Hi Kristian
I get the option box for the reason I am stopping the listing. The stopping Item indicator box appears, a stopping message appears very quickly in the activity window and then normal Gs activity resumes. The item is still active though.
Regards David
0404499979
Did you already check the listing status in your browser?
Yes still active. I first noticed it earlier when the auto-End function did not work. It was set for one hour prior. Items were down to 3 mins remaining when I twigged on.
Regards David
0404499979
oops. I thought you were talking of the auto cancel feature
Maybe this is an issue with your eBay token/Keychain.
It might be required to renew the eBay token completely:
Thanks Kristian
That was the problem. I just happened to test it out on the 2 of the 3 accounts that had the token issue.
