I am fine tuning the Pro ‘Maintstream’ template. For the past 30 minutes, I have been trying to figure out why my store categories are not showing in my live test listing. The correct options have been set in properties and within the GS7 preferences. The only store category that shows up in the listing is “other”.
Thanks for the reply. Yes, I did. And I refreshed my access token for what it’s worth.
I’m going to try to create a new listing using the template and will report back as to whether the problem still exists.
