i imported all my GS7 auction into GS8 when I opened it.
have noticed unisual line spacins, that wernt there in GS7. ??? any reason why?
means I have to hand edit all my listings again.
Regards Sandy.
Regards Sandy.
Please see my reply here:
Ok, but am prety sure when i installed GS8 for thefirst time an dopened it it only aked if i wanted to import my listing, but did not say from ebay. I sould have taken a screen shot,
anyway… what is done is done…
thanks for the explanation.
regards
Sandy
That’s true, GarageSale does not import from eBay automatically. You must have select that function manually. Maybe you already did that in the past in GarageSale 7.
