I have to import csv listings
there are 12 images
how should i fill in the picurl field to have a valid advertisement?
I’d like to know both by putting the images locally and in an ftp repository … thanks a lot for your help
below my try:
https://www.pfricambi.it/public_html/images/ricambi/PF00394_1.jpg|https://www.pfricambi.it/public_html/images/ricambi/PF00394_2.jpg|https://www.pfricambi.it/public_html/images/ricambi/PF00394_3.jpg
You have specify what column in your CSV file is mapped to the “Image URL” field in the CSV import panel. Please see the help here for more details about this feature:
https://manual.iwascoding.com/gs8/en/Listings_Section-Importing_from_CSV.html
I don’t think I can help with that, sorry.
Does it have to be CSV? If you could convert your data to GarageSale’s XML input format, multiple image URLs should work:
https://manual.iwascoding.com/gs8/en/Listings_Section-Importing_from_XML.html
