WCV
March 7, 2024, 10:28pm
1
I am under the yearly license (paid until Dec. I believe) and this popped up?
Why is that, I am using
GarageSale 9.7a5 (1644) is currently the newest version available.
There is no option to just type in my license info.
Thanks for any help here
GarageSale Pro
$149.90 per year
Your plan renews on December 15, 2024.
Did this to me as well on 9.7a3. Paul had to fix it on their end. Try restarting GS and your computer a couple times. The Microsoft solution!
How do I switch from monthly to yearly?
I pay mine under the Pro tab in preferences.
Try to re-sign in with your Pro account. You can do this e.g. in the GarageSale preferences > Pro.
You can do this by cancelling your monthly subscription, and once the paid period has ended you re-subscribe with the yearly option.
That worked for me Kristian
vjl
March 13, 2024, 10:37am
9
FYI, I had this same issue trying to list items with 9.7. Yearly Pro subscriber. Checking for updates, and installing 9.7.1 fixed it for me. How did this bug make it into the production version? I never installed any alpha/beta version [assuming a3 and a5 mentioned in this support thread are alpha versions?]
CAL
March 13, 2024, 6:32pm
10
GS asked me to buy a subscription today after updating to 9.7.1 a few days ago. Signing back in fixed the problem.
system
Closed
March 23, 2024, 6:33pm
11
