I have just upgraded to GarageSale Pro for the main reason of allowing synchronisation between my Mac and Macbook - I have managed the first step of uploading the data to the Sync server but when I try to download to the laptop I get the following message…
‘Synchronization could not be enabled because another computer is currently transferring data for your account. Please try again later.’
Trying later does not change things - any suggestions?
Are you sure your first Mac completed the initial upload successfully? If it did so, your second Mac should have no issues connecting to the sync server.
