My 2 Macs have stopped syncing with each other. On my Mac Pro the conflicts will not solve It will only say 1 of 2 solved. They are both Hierarchy conflicts. No mater what I click on the one will not go away. Any help would be great.
Here are 2 screen shots. Cant get passed this.
I am afraid, you need to re-do the synching setup on your Mac Pro.
At first export all listings that only exist on this particular Mac. Next, open the GarageSale preferences > Pro and disable synching there. Wait a moment, then enable synching again and select “Enable Synching and Replace my Local Data” when prompted.
To avoid hierarchy conflicts in future please have a look at “Notes on handling folders” in the help’s Synching chapter (you have to scroll down a bit).
I disabled synching on both computers and enabled synching again. I selected to upload the data from the computer and replace cloud data. It has now been stuck like this for the past couple of hours.
When I click on File and then Synching it says busy uploading.
I did it this way to not loose about 100 auctions that I have not listed yet.
Did you get an error message during that upload process?
As long as you don’t get an error, the process is still ongoing (normally).
