if I set a new auction template listing design to a pro design and edit the properties
And then import a new listing from eBay
Can I apply the listing design and properties to the new listing? If I select the pro design it reverts to it’s original properties(which are blank)
Kind Regards,
I believe that’s only possible in GarageSale 7, which has a new copy/paste components feature.
Thank you for the fast reply. I am now currently using Garage Sale 7 and I just found the "copy/paste components feature. I needed to right click on the listing template name.
Thank you so much!
