Not sure why buy it keeps asking me to download a new token and everything I try its these errors.Thanks
Could it be that you are using an older version of GarageSale?
The latest version is GarageSale 9.9.1.
If there is nothing non-standard about your network, this might be a (hopefully temporary) site issue on eBay’s side, yes.
Please give refreshing the eBay token another try later the day.
You mentioned that you are using an older Mac laptop. What version of macOS is installed?
I am using High Sierra 10.13.6, I do plan to move to a new computer which I have here already lol
Still cant generate a token.
Should I downgrade to an earlier version of GS?
Sounds like a good idea, you should do that!
Regarding the error “This Token has been revoked by App” that you get, give this a try:
- Remove your eBay account from the GarageSale preferences > Accounts
- Quit GarageSale if running.
- Open the macOS “Keychain Access” application and enter “GarageSale eBay Account” in the search field. (If you don’t find anything try it with “ebay token”.) Right-click on the eBay account token in the Keychain and select “Delete”.
- If done, restart your Mac, start GarageSale and try to add your eBay access token in the GarageSale preferences > Accounts.
If prompted, allow GarageSale access to your Keychain by clicking on “Always Allow”.
Thank you. I am actually setting up the new Mac now, its time lol
When I put the new Mac and log in, it wants me to sign up for another subscription. I logged into my subscription account already.
Do I have to log out of the old computer first?
Disregard, had to close the app on the payment screen and restart and the subscription was successfully registered. Now need to get the data over.
Also I copied the GS9 folder with all the data, I just paste it on the new computer folder right?
The GS9 folder
This also brings over the preferences and settings?
Thanks
UPDATE: I am so proud of myself. I managed to get everything transferred to the new computer and managed to manually bring over the file that brought over everything. Back in business literally with a newer Mac. Thanks again for your help and finally getting me to do this! lol
I’m having similar issues with the token not being downloaded when renewing access. I get all the way through until it says to click to “Go Back to Garage Sale” and then it says “Safari cannot open the page because the address is invalid”.
I have tried the suggestion mention about removing account token in Keychain Access and still it’s not working.
Please advise!
What version of macOS are you using?
And what version of GarageSale?
