After I re-created my GS DB by importing all from Ebay, most, if not all, my listings seem to have multiple htm break tags in them.
I third bulk and replace on:
→ Noting happened ( as expected).
Then I tried
Gs crashed.
Not too worried about the crash but does anyone have any idea on how to solve this - automatically.
There seem screenshots to be missing in your post.
However, in the “Find & Replace” window did you try it with the “Exact Search” option enabled? This should allow you to search for HTML code.
https://manual.iwascoding.com/gs8/en/Listings_Section-Bulk_Editing.html#bulk-find-and-replace
Strange that you cannot see it because it is visible in your reply to me.
Not sure if I tried ‘exact’ or not.
I have also just noticed that the tags include and .
Yes that worked, Kristian. Must confess, I had not noticed that checkbox.
system
Closed
June 17, 2021, 10:34am
#5
