Is there any way to disable the option for argos click and collect? I cant see it it the inspector or postage preferences screen.
Can you send a screenshot (cmd-shift-4) of the screen that’s troubling you. Unless specifically select that option, it should not be active in your listing.
I have an active listing that has bids on it so cant change anything, but when I go in to revise i see the option is ticked.
That’s strange. As far as I recall GarageSale doesn’t even offer this option.
Have you checked your eBay account preferences on the eBay website? Maybe eBay UK offers that option for your listings by default?
i found the global setting in site preferences in my ebay account. All sorted. Thanks.
