Just wondering if any of the GS startup options will fix this problem. A number of items are marked as finished but I cannot delete them
My colours.
An empty trash can
The issue
My colours.
An empty trash can
The issue
Just realised that I cannot delete them from a smart group BUT there is still an issue because if I reveal the original
GS crashes - every time.
If you’re still using the beta version of GarageSale 8.3.6 can you please update to the final version?
After doing this please send us the crash report file.
If you have already done this, please send us your Crash ID that can be found in the “About GarageSale” panel.
Also, do you actually find one of the listings in question if you use the search function?
I am afraid my Db as really crashed again and I going to have to start again from Zero.
The Containers folder it very confusing now with three instances of ‘GarageSale’ as named from ‘com.iwascoding.garagesale8’ by Apple.
I used to just add .old or .date when i wanted to make a copy.
