here you go
it’s after list an item right before finish uploading the images
*edit also I usually use garagesale free picture service for a while
here you go
Thank you for the screenshot.
It’s a different eBay error than the one discussed in this thread initially.
There seems to be an issue with the upload to eBay’s image server. Often this is just a temporary issue with their servers so it should work at a later time without issues.
If not, maybe something is blocking the connection, e.g. a Firewall, proxy server settings or tools like Kaspersky, LittleSnitch, MacKeeper, HandsOff, cisco anyconnect, GlimmerBlocker or any other AdBlocker.
Does it work if you switch to GarageSale’s free image service in the GarageSale preferences>Image Server?
