Unknown Authorisation Error from Ebay's OpenAPI
Just upgraded to 9.4.1 (1545) and I’m getting an ‘Unknown Authorisation Error from Ebay’s OpenAPI’ message when I try and list.
Help!
You most likely just need to refresh your eBay access token.
eBay tokens expire automatically after a specific period of time. To refresh your token, select your account in the GarageSale preferences > Accounts and click on “Refresh Token”.
https://manual.iwascoding.com/gs8/en/GarageSale_Preferences-Accounts.html
Thanks Kristian that worked. It had been a while since I’d needed to do that and I’d forgotten.
