Any way to Search for, or Smart Group, Unknown categories???
Or at least find (show) the Category Number of the old Unknown category in the Category popup window?
I have over 115,000 listings, and MOST of my listings are in the “Model Railroads & Trains” category, which got MOST of it’s categories Retired and a few New categories added during eBay’s October 12 category reorganization.
A way (Smart Group?) to show all listings with an Unknown category, that I can sort by Category Number, would be great!
I asked the same question about a year back. The answer was no. I hope the answer is now yes though, because I too have many category ‘unknown’ items. Happened on the last big eBay category update, just recently.
With 1000 listing items selected, every click in the Attributes popup window takes >30 seconds. Just trying to add a new item specific attribute to several listings. 500 listings selected takes many seconds for each click in the popup window, and even 100 selected listings gets a spinning beachball…
Using macOS 11.6 (20G165) on a iMac (24-inch, M1, 2021) 16GB RAM.
