UPC Lookup for Movies Doesn't Work
When I type the UPC into the product search, it will not pull it up. If I search by the title and select the item, GarageSale will input the UPC so I know it has access to this information.
How do I use UPC rather than title because it would save time and there are instances where there are multiples of the same title that I have to look through to find the one that matches UPC.
Mark
sorry, in the API we are using there is no way to search for the UPC.
Regards,
Try prepending the barcode with a 0 (zero) when doing the search. For whatever reason, that’s usually needed when searching the eBay product catalog.
Yes, there is. In the GS product search box, it literally says “Search product or enter barcode
Thanks so much. This works well.
