Hi there,
I ran into problems with v7 and stopped using it. Just trying to update to v9 but keep getting the error message – it seems to download but ditches at 100%.
Any advice welcome, I’ve been using Garage Sale since 2007 and can’t stand using the ebay thing for listings.
Siobhán
Are you trying to use the update mechanism from within GarageSale 7?
If so, please download GarageSale 9 directly from our website here instead:
On first launch it will ask you to import your GarageSale 7 database so you won’t lose any work:
Thanks, sorted. Struggling with other issues now!
What issues did you run into?
