Hi - figuring out best way to upgrade!
If I start with a fresh install without importing, how do I redownload a PRO design that I previously bought? And once I install that PRO design, if I import individual listings, will they then come through with all of the info I use in my PRO design? Thanks! Pete
If you are referring to a paid design: You can re-download it by selecting “Show Design Templates” from GarageSale 's Window menu. There click on the cart icon in the toolbar and enter the transaction ID of the purchase to re-download your design.
You find the transaction ID in the invoice mail. If you no longer have it, please contact our support (or I send you a PM).
Please note that GarageSale needs a license or a Pro subscription to be able to download paid designs.
