Hello, i have the same problem since few week, upload doesn’t work, i have reinstall my box (internet) reinstall the garagesale.app and the result is the same… please help me
“Internal error to the application” is returned by eBay’s server when there a having issues.
However, it’s very uncommon that you get this error since weeks!
Do you get this error with all listings or only this specific one?
hello,
i have this error on each annonces (with planning or not)
i try to upload to my own server and i have a errors
i’m really disapoint
best
the button don’t display
Does it work if you try to switch to a different image server?
No it’s the same, i try with the tree option Ebay, GarageSale Server and my own server
The result it’s the same
some questions that may help us understand/reproduce the issue:
- Which version of GS are you using?
- Do you use URL images and can you verify that all images are valid?
- Do you have this error in all listing or just in some?
- Does the error occur also when startig only one single listing?
- Do you have a stable internet connection?
Please export the listing you have issues with and send it to me. I will try to reproduce the error here.
