This seems to happen after I have performed an ‘Update All’
Is it correct to do so? Can it be turned off?
Are you sure you don’t have any listings left with the auto-restart option enabled? These listing might just have ended, and GarageSale is trying to re-upload them.
I wish I could give you a definitive answer, Ilya, but I can’t. I am trying to cross check my items so iy=t is possible that some had been left with the restart on.
