Hi new to Garagesale and a bit stuck have looked through tutorials but cant find the answer!
I am wanting to list variations on my lisitngs i manage to add them but when I click to list it comes back with an error saying price invalid - I am confused as what i should be doing on the options tab should i put a price in etc?
If you use variations you have to define the price for each variation in the variations panel. You can’t use the “Buy It Now” pricie field in the “Options” Inspector then.
If it helps to explain the issue, feel free to post a screenshot of the error you get here.
Could you export one of the listings in question using GarageSale’s export function (File menu > Export Listings), zip it and then post it here or send it to me so I can have a closer look at it?
Please also let me know which version of GarageSale you have installed, version 7 or version 8? (Just select ‘About GarageSale’ from the ‘GarageSale’ menu in GarageSale.)
Please zip/compress the exported listing before posting it here. (Right-click on the exported file and sleect “Compress”.)
If it still won’t work, please just send the listing to the GarageSale support. https://www.iwascoding.com/Contact/
It seems the price you set for your variants is too low. I’m not sure what the minimum sales price in that category is, but the error went away after I set to the prices for the variations to 5 pounds.
