Hello,
I have just noticed that for some listing the number of visit seems to be negative… how is it possible?! I supposte there is a problem…
Thank you for any clarification
Federico
Hello,
Federico
I have noticed exactly the same after importing listing from eBay. I hadn’t noticed it before. I have got a new version today so maybe that caused it.
I am using 7.0.5 beta 2 (781), I did not notice it before but to be honest that was the first time I paid attention… those listings where started since some minutes so were very new, now are all positive numbers…
If you check the number of views in the Inspector, do you see the negative number there, too?
Next time it happens I will check, as written before now are all positive views… that’s not a big problem, but just a funny thing
