What is Perform Auto Cancellation
GS2QS
Can someone explain to me what these mean? I come from GS7 and don’t know really what these mean? The Help section within GS9 does not address these two options either.
Thank you.
Please see the help here:
Perform Auto Cancellation: This is only required for the optional Auto-Cancel feature. It lets you define how often GarageSale should perform/check the auto cancellation process. If you selected “Never”, you need to invoke the “Stop Listings Due for Automatic Cancellation” command from the “Listing” menu manually.
https://manual.iwascoding.com/gs8/en/GarageSale_Preferences-eBay.html#advanced
Auto Cancel feature:
https://manual.iwascoding.com/gs8/en/Listings_Section-Ending_Listings.html#automatic-cancellation
attributes are “item specifics”
Thank you both for the replies and answers.
