I’m having trouble re-arranging photos. I have tried dragging and dropping them in the image field in Editor mode but I usually end up with duplicates somehow and the same goes for the little thumbnails underneath the Gallery Image. What am I doing wrong or is there a better way?
You’re using GarageSale 7.0.15, I guess?
It sounds you’re doing it correctly. Can you please check the tutorial video # 4 here?:
https://www.iwascoding.com/GarageSale/Support.html#VideoTutorials
Watched the video and tried rearranging from Editor Mode instead. That works much better for me I’m not getting the duplicates or other unintended results. Thank you.
