A CRASH happens during the relisting process!
A crash is occurring during the relist process. It has happened 3 days in a row. Restarted GS and the process continues with no further crash. Once is ok, twice is worrying but the third time I figure it needed reported. Let me know what you need to find the cause.
Maybe the crash log file gives some clues. You find it in your User Library* here:
~/Library/Logs/DiagnosticReports
*Please note: The User Library is hidden by default. To access it click the Finder’s “Go” menu and press the option (alt) and shift key to make the User Library show up in the menu. Selecting it will open it in the Finder.
Also, could you please lookup your personal “Crash ID” from the “About GarageSale” window, and copy & paste it here?
Console logs might be helpful, too.
Crash ID: 03044c6f40ca5ebca67dc87af2e8aa49
Cant seem to press the right keys to get the “~/Library/Logs/DiagnosticReports”
“Console logs”- No idea how to locate these
There are different ways to get there. Give this another try:
  1. Open a Finder window and navigate to your Home folder.
  2. From the Finder menu, click View > Show View Options.
  3. Select the “Show Library Folder” checkbox.
What is the crash log under?
should be Logs/DiagnosticReports
How do you want them?
the latest one from today I guess
copy paste contents? or email?
feel free to add the whole file here
It says 3 times Too big. Cut it up?
Try doing a “compress”, with a Right-Click in the Finder.
I had a similar crash 3 days ago, ID: 74ce075b3864af068a184cb82f31641a
GarageSale-2023-06-23-143919.ips.zip (9.0 KB)
Translated Report (Full Report Below)
Process: GarageSale [22428]
Path: /Applications/GarageSale 9.4b9.app/Contents/MacOS/GarageSale
Identifier: com.iwascoding.garagesale9
Version: 9.4b9 (1530)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-06-26 07:51:39.0090 -0400
OS Version: macOS 12.6.7 (21G651)
Report Version: 12
Anonymous UUID: 52D105C3-0295-0636-C1C8-022EF165A464
Time Awake Since Boot: 200000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000171a7785d650
Exception Codes: 0x0000000000000001, 0x0000171a7785d650
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [22428]
VM Region Info: 0x171a7785d650 is not in any region. Bytes after previous region: 25395475109457 Bytes before following region: 80150674418096
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
WebKit Malloc 19d400000-19f400000 [ 32.0M] rw-/rwx SM=PRV
—> GAP OF 0x5ffe60c00000 BYTES
MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x7ff818f11293 objc_retain + 35
1 GarageSale 0x103e72f34 -[GSOutlineViewDataSource outlineView:viewForTableColumn:item:] + 57
2 AppKit 0x7ff81bc2c1ef -[NSTableView(NSTableViewViewBased) makeViewForTableColumn:row:] + 87
3 AppKit 0x7ff81bc2b75b -[NSTableRowData _addViewToRowView:atColumn:row:] + 285
4 AppKit 0x7ff81bc284cb -[NSTableRowData _preparedRowViewForRow:storageHandler:] + 1068
5 AppKit 0x7ff81bc27fa6 -[NSTableRowData _addRowViewForVisibleRow:withPriorView:] + 290
6 AppKit 0x7ff81bc27db6 -[NSTableRowData _addRowViewForVisibleRow:] + 312
7 AppKit 0x7ff81bc275e9 -[NSTableRowData _updateVisibleRowEntries] + 955
8 AppKit 0x7ff81bc26fad -[NSTableRowData updateVisibleRowViews] + 484
9 AppKit 0x7ff81bd43dfd -[NSTableView prepareContentInRect:] + 267
10 AppKit 0x7ff81bd02bfe -[NSView _updateSuggestedContentRectToValue:] + 378
11 AppKit 0x7ff81bd02a76 -[NSView _updateSuggestedContentRect] + 82
12 AppKit 0x7ff81bd02a12 -[NSView _updateSuggestedContentRectForVisibleRectChange] + 165
13 AppKit 0x7ff81c4e8ae1 -[NSScrollView _handleBoundsChangeForSubview:] + 338
14 AppKit 0x7ff81bc42e24 -[NSView _postBoundsChangeNotification] + 61
15 AppKit 0x7ff81bbf1734 -[NSView setBoundsOrigin:] + 449
16 AppKit 0x7ff81bbf1554 -[NSClipView setBoundsOrigin:] + 42
17 Foundation 0x7ff819fede46 _NSSetPointValueAndNotify + 180
18 Foundation 0x7ff819f741ea -[NSObject(NSKeyValueCoding) setValue:forKey:] + 353
19 AppKit 0x7ff81bc15cc9 -[NSView setValue:forKeyPath:] + 398
20 AppKit 0x7ff81beb45c8 -[NSClipView setValue:forKeyPath:] + 191
21 AppKit 0x7ff81bd48b25 NSAnimationManagerStopAnimation + 99
22 AppKit 0x7ff81bd48334 __40+[NSAnimationManager performAnimations:]_block_invoke_3 + 1259
23 AppKit 0x7ff81bb9916b +[NSAnimationContext runAnimationGroup:] + 55
24 AppKit 0x7ff81bd47e40 __40+[NSAnimationManager performAnimations:]_block_invoke_2 + 138
25 AppKit 0x7ff81bbccbf7 NSPerformVisuallyAtomicChange + 132
26 AppKit 0x7ff81bd479c5 +[NSAnimationManager performAnimations:] + 1227
27 AppKit 0x7ff81bd47437 -[NSScreenDisplayLink _fire] + 156
28 AppKit 0x7ff81c4d9f60 ___NSRunLoopTimerCreateWithHandler_block_invoke + 34
29 CoreFoundation 0x7ff81915df49 CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION + 20
30 CoreFoundation 0x7ff81915da38 __CFRunLoopDoTimer + 923
31 CoreFoundation 0x7ff81915d5a8 __CFRunLoopDoTimers + 307
32 CoreFoundation 0x7ff819143cb6 __CFRunLoopRun + 2010
33 CoreFoundation 0x7ff819142e1c CFRunLoopRunSpecific + 562
34 HIToolbox 0x7ff821df35e6 RunCurrentEventLoopInMode + 292
35 HIToolbox 0x7ff821df334a ReceiveNextEventCommon + 594
36 HIToolbox 0x7ff821df30e5 _BlockUntilNextEventMatchingListInModeWithFilter + 70
37 AppKit 0x7ff81bb7df6d _DPSNextEvent + 927
38 AppKit 0x7ff81bb7c62a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1394
39 AppKit 0x7ff81bb6ecd9 -[NSApplication run] + 586
40 AppKit 0x7ff81bb42c57 NSApplicationMain + 817
41 dyld 0x10c34b52e start + 462
Thread 1:
0 libsystem_kernel.dylib 0x7ff8190443da __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff81907ea6f _pthread_cond_wait + 1249
2 libc++.1.dylib 0x7ff818fdcd22 std::__1::condition_variable::wait(std::__1::unique_lockstd::__1::mutex&) + 18
3 GarageSale 0x10426d9d3 leveldb::(anonymous namespace)::PosixEnv::BackgroundThreadMain() + 75
4 GarageSale 0x10426d987 leveldb::(anonymous namespace)::PosixEnv::BackgroundThreadEntryPoint(leveldb::(anonymous namespace)::PosixEnv*) + 9
5 GarageSale 0x10426da78 void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_deletestd::__1::__thread_struct >, void ()(leveldb::(anonymous namespace)::PosixEnv), leveldb::(anonymous namespace)::PosixEnv*> >(void*) + 40
6 libsystem_pthread.dylib 0x7ff81907e4e1 _pthread_start + 125
7 libsystem_pthread.dylib 0x7ff819079f6b thread_start + 15
Thread 2:
0 libsystem_kernel.dylib 0x7ff81904196a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x7ff819041cd8 mach_msg + 56
2 GarageSale 0x1046a4002 exception_server_thread + 154
3 libsystem_pthread.dylib 0x7ff81907e4e1 _pthread_start + 125
4 libsystem_pthread.dylib 0x7ff819079f6b thread_start + 15
Thread 3:: com.apple.NSEventThread
2 CoreFoundation 0x7ff81914534d __CFRunLoopServiceMachPort + 319
3 CoreFoundation 0x7ff8191439d8 __CFRunLoopRun + 1276
4 CoreFoundation 0x7ff819142e1c CFRunLoopRunSpecific + 562
5 AppKit 0x7ff81bceb98e _NSEventThread + 132
Thread 4:: com.apple.NSURLConnectionLoader
5 CFNetwork 0x7ff81dd6e6e0 0x7ff81db25000 + 2397920
6 Foundation 0x7ff819f9a984 NSThread__start + 1009
7 libsystem_pthread.dylib 0x7ff81907e4e1 _pthread_start + 125
8 libsystem_pthread.dylib 0x7ff819079f6b thread_start + 15
Thread 5:: LocalStorage
2 JavaScriptCore 0x7ff831a13f20 WTF::ParkingLot::parkConditionallyImpl(void const*, WTF::ScopedLambda<bool ()> const&, WTF::ScopedLambda<void ()> const&, WTF::TimeWithDynamicClockType const&) + 2416
3 WebKitLegacy 0x7ff82fbb306a bool WTF::Condition::waitUntilUncheckedWTF::Lock(WTF::Lock&, WTF::TimeWithDynamicClockType const&) + 154
4 WebKitLegacy 0x7ff82fbb67d5 WebCore::StorageThread::threadEntryPoint() + 245
5 JavaScriptCore 0x7ff831a31306 WTF::thread::entryPoint(WTF::thread::NewThreadContext*) + 246
6 JavaScriptCore 0x7ff831854629 WTF::wtfThreadEntryPoint(void*) + 9
Thread 6:: com.apple.CFStream.LegacyThread
5 CoreFoundation 0x7ff8191c0b48 _legacyStreamRunLoop_workThread + 251
Thread 7:: AMCP Logging Spool
0 libsystem_kernel.dylib 0x7ff8190419a6 semaphore_wait_trap + 10
1 caulk 0x7ff821b7f2e6 caulk::mach::semaphore::wait_or_error() + 16
2 caulk 0x7ff821b67148 caulk::concurrent::details::worker_thread::run() + 36
3 caulk 0x7ff821b66e0c void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::)(), std::__1::tuplecaulk::concurrent::details::worker_thread* > >(void) + 41
4 libsystem_pthread.dylib 0x7ff81907e4e1 _pthread_start + 125
5 libsystem_pthread.dylib 0x7ff819079f6b thread_start + 15
Thread 8:: WebKitWebRTCNetwork
0 libsystem_kernel.dylib 0x7ff819049d4a __select + 10
1 libwebrtc.dylib 0x7ff821267752 rtc::PhysicalSocketServer::Wait(int, bool) + 1074
2 libwebrtc.dylib 0x7ff8213e7fcf rtc::thread::Get(rtc::Message*, int, bool) + 911
3 libwebrtc.dylib 0x7ff8213e90b8 rtc::thread::Run() + 200
4 libwebrtc.dylib 0x7ff8213e8ebf rtc::thread::PreRun(void*) + 79
5 libsystem_pthread.dylib 0x7ff81907e4e1 _pthread_start + 125
6 libsystem_pthread.dylib 0x7ff819079f6b thread_start + 15
Thread 9:: WebKitWebRTCSignaling
2 libwebrtc.dylib 0x7ff82114cf75 rtc::Event::Wait(int, int) + 661
3 libwebrtc.dylib 0x7ff82120b722 rtc::NullSocketServer::Wait(int, bool) + 18
4 libwebrtc.dylib 0x7ff8213e7fcf rtc::thread::Get(rtc::Message*, int, bool) + 911
5 libwebrtc.dylib 0x7ff8213e90b8 rtc::thread::Run() + 200
6 libwebrtc.dylib 0x7ff8213e8ebf rtc::thread::PreRun(void*) + 79
Thread 10:: rtc-low-prio
2 libwebrtc.dylib 0x7ff82114d015 rtc::Event::Wait(int, int) + 821
3 libwebrtc.dylib 0x7ff8213e2ce0 std::__1::__function::__func<webrtc::(anonymous namespace)::TaskQueueStdlib::TaskQueueStdlib(std::__1::basic_string_view<char, std::__1::char_traits >, rtc::ThreadPriority)::$_1, std::__1::allocator<webrtc::(anonymous namespace)::TaskQueueStdlib::TaskQueueStdlib(std::__1::basic_string_view<char, std::__1::char_traits >, rtc::ThreadPriority)::$_1>, void ()>::operator()() + 256
4 libwebrtc.dylib 0x7ff821271740 std::__1::__function::__func<rtc::PlatformThread::SpawnThread(std::__1::function<void ()>, std::__1::basic_string_view<char, std::__1::char_traits >, rtc::ThreadAttributes, bool)::$_1, std::__1::allocator<rtc::PlatformThread::SpawnThread(std::__1::function<void ()>, std::__1::basic_string_view<char, std::__1::char_traits >, rtc::ThreadAttributes, bool)::$_1>, void ()>::operator()() + 192
5 libwebrtc.dylib 0x7ff821271408 rtc::(anonymous namespace)::RunPlatformThread(void*) + 24
Thread 11:: Dispatch queue: com.iwascoding.operation-queue.uploads (QOS: UNSPECIFIED)
0 libsystem_kernel.dylib 0x7ff8190442ae __semwait_signal + 10
1 libsystem_c.dylib 0x7ff818f58863 nanosleep + 196
2 Foundation 0x7ff81a02ae61 +[NSThread sleepForTimeInterval:] + 151
3 GarageSale 0x1041c8781 -[IHURLSession synchronouslyDownloadRequestToFile:] + 867
4 GarageSale 0x1041c8bde -[IHURLSession synchronouslyDownloadDataToFile:] + 51
5 GarageSale 0x1041c8243 +[IHURLSession sendSynchronousRequest:delegate:timeoutInterval:disableCaching:allowRedirect:] + 145
6 GarageSale 0x103d7d9f9 -[IHEbayConnector(ImageUpload) sendImageUploadRequest:filePath:error:] + 1927
7 GarageSale 0x103e9fdcb -[GSEPSUploadImageOperation uploadImage] + 384
8 GarageSale 0x103e53e4f -[GSImageUploadOperation internalMain] + 431
9 GarageSale 0x1041c5da6 -[IHNSOperation main] + 363
10 Foundation 0x7ff819f8399f NSOPERATION_IS_INVOKING_MAIN + 17
11 Foundation 0x7ff819f82c0b -[NSOperation start] + 785
12 Foundation 0x7ff819f828e1 NSOPERATIONQUEUE_IS_STARTING_AN_OPERATION + 17
13 Foundation 0x7ff819f827b8 __NSOQSchedule_f + 182
14 libdispatch.dylib 0x7ff818ed43c0 _dispatch_block_async_invoke2 + 83
15 libdispatch.dylib 0x7ff818ec7317 _dispatch_client_callout + 8
16 libdispatch.dylib 0x7ff818ec9d7c _dispatch_continuation_pop + 453
17 libdispatch.dylib 0x7ff818ec943f _dispatch_async_redirect_invoke + 704
18 libdispatch.dylib 0x7ff818ed6ac2 _dispatch_root_queue_drain + 343
19 libdispatch.dylib 0x7ff818ed725c _dispatch_worker_thread2 + 160
20 libsystem_pthread.dylib 0x7ff81907af8a _pthread_wqthread + 256
21 libsystem_pthread.dylib 0x7ff819079f57 start_wqthread + 15
Thread 12:: JavaScriptCore libpas scavenger
2 JavaScriptCore 0x7ff831ab6f25 scavenger_thread_main + 1397
Thread 13:: Dispatch queue: com.iwascoding.operation-queue.uploads (QOS: UNSPECIFIED)
Thread 14:
0 libsystem_pthread.dylib 0x7ff819079f48 start_wqthread + 0
Thread 15:
Thread 16:
Thread 17:
2 Foundation 0x7ff81a06ca19 +[NSThread sleepUntilDate:] + 171
3 ImageKit 0x7ff91f61cd43 -[IKTaskManager taskLoop] + 2059
4 Foundation 0x7ff819f9a984 NSThread__start + 1009
Thread 18:
Thread 19:
Thread 20:: Dispatch queue: com.iwascoding.operation-queue.uploads (QOS: UNSPECIFIED)
Thread 21:: Dispatch queue: com.iwascoding.operation-queue.uploads (QOS: UNSPECIFIED)
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000971a7785d630 rbx: 0x0000600001c29420 rcx: 0x0000171a7785d630 rdx: 0x031dfff85a605655
rdi: 0x00006000057fd630 rsi: 0x00007ff83349f158 rbp: 0x00007ff7bc2df040 rsp: 0x00007ff7bc2deff8
r8: 0x00006000057fd630 r9: 0xfffeffffffffffff r10: 0x000060000056e130 r11: 0x00007ff81bb4baa4
r12: 0x000060000066f2a0 r13: 0x00007ff1301c1e00 r14: 0x00007ff818f11270 r15: 0x00006000057fd630
rip: 0x00007ff818f11293 rfl: 0x0000000000010206 cr2: 0x0000171a7785d650
Logical CPU: 2
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
5f 5d c3 49 8b 46 20 4c-21 f8 48 8b 48 08 48 89 _].I.F L!.H.H.H.
c8 48 83 e0 fe f6 c1 01-75 1e 8b 40 08 83 c0 07 .H…u..@…
83 e0 f8 48 01 f0 48 83-f8 11 be 10 00 00 00 48 …H..H…H
0f 43 f0 e9 68 ff ff ff-48 8b 00 eb dd 48 85 ff .C..h…H…H..
0f 84 83 00 00 00 89 f8-83 e0 01 48 85 c0 75 79 …H..uy
48 8b 07 48 b9 f8 ff ff-ff ff 7f 00 00 48 21 c1 H..H…H!.
[48]8b 51 20 f6 c2 04 74-38 a8 01 74 56 48 b9 00 H.Q …t8..tVH.. <==
00 00 00 00 00 00 01 48-89 c2 48 c1 ea 37 74 49 …H..H..7tI
48 89 c2 48 01 ca 72 12-f0 48 0f b1 17 74 3a a8 H..H..r..H…t:.
01 75 e4 31 f6 e9 4d fe-01 00 31 f6 e9 4c b0 00 .u.1..M…1..L..
00 66 83 79 1c 00 79 0e-83 e2 02 48 85 d2 74 06 .f.y..y…H..t.
f6 41 28 02 75 17 48 8b-35 18 fe 8d 41 ff 25 5a .A(.u.H.5…A.%Z
Binary Images:
0x7ff818f0b000 - 0x7ff818f44fff libobjc.A.dylib () <4d9b0dca-7151-3875-b98e-b255db8267a8> /usr/lib/libobjc.A.dylib
0x103c1d000 - 0x1048c8fff com.iwascoding.garagesale9 (9.4b9) /Applications/GarageSale 9.4b9.app/Contents/MacOS/GarageSale
0x7ff81bb3f000 - 0x7ff81c9cefff com.apple.AppKit (6.9) <1a1a9da7-da66-31da-92cd-51b9cf968145> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff819f42000 - 0x7ff81a2fefff com.apple.Foundation (6.9) <3458e3ba-4778-3b73-80c8-19245d425b38> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff8190c5000 - 0x7ff8195c7fff com.apple.CoreFoundation (6.9) <70b99b27-1b5b-33c4-b401-2ecdb80f3303> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff821dc5000 - 0x7ff8220b8fff com.apple.HIToolbox (2.1.1) <06fdecd6-9f69-397b-b1e2-a8226c0ba7ed> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x10c346000 - 0x10c3b1fff dyld (
) <2517e9fe-884a-3855-8532-92bffba3f81c> /usr/lib/dyld
0x7ff819040000 - 0x7ff819077fff libsystem_kernel.dylib () /usr/lib/system/libsystem_kernel.dylib
0x7ff819078000 - 0x7ff819083fff libsystem_pthread.dylib (
) /usr/lib/system/libsystem_pthread.dylib
0x7ff818fd1000 - 0x7ff819029fff libc++.1.dylib () /usr/lib/libc++.1.dylib
0x7ff81db25000 - 0x7ff81dfb4fff com.apple.CFNetwork (1335.0.3.2) <91c33dfa-4410-3b70-b512-4519bc14319b> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7ff831850000 - 0x7ff832e63fff com.apple.JavaScriptCore (17613) <3b6788e4-14ab-3a85-b507-2ec9495c9e76> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7ff82fb56000 - 0x7ff82fd05fff com.apple.WebKitLegacy (17613) /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7ff821b65000 - 0x7ff821b86fff com.apple.audio.caulk (1.0) <8e7b3d95-1d47-3f17-9512-c5fcc30792c2> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff820fe6000 - 0x7ff821949fff libwebrtc.dylib (
) /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x7ff818f48000 - 0x7ff818fd0fff libsystem_c.dylib () /usr/lib/system/libsystem_c.dylib
0x7ff818ec4000 - 0x7ff818f0afff libdispatch.dylib (
) <1a04b380-76e4-3e4b-b0fc-9837533d021d> /usr/lib/system/libdispatch.dylib
0x7ff91f5f1000 - 0x7ff91f848fff com.apple.imageKit (3.0) <8f6773fe-d6d1-3f16-b303-a1967a61baa4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
this is deleted and is 20 characters
Please just post the log file here (as a file; zip file is fine).
Can you delete your last two post with the log text, please?
@rlmartin @Neal
Thank you. Not sure if these crash logs are actually useful for @ilja or @Paul but we will see.
Maybe console logs are more helpful.
where are these? Not computer savvy here, sorry. I can drive a car but cant tear into an automatic transmission to repair it.
No problem, I will send you step-by-step instructions IF console logs should be required.
