dmboxon
February 7, 2018, 9:27am
#1
After updating to the newest version of Garagesale, I cannot scroll down within the listing in edit mode. Although the text is very long, I cannot access it by scrolling.
I found a similar problem described by another user here, and it was resolved in the past, but that solution no longer works:
Hi, I’m unable to scroll down in editor mode to amend text on either a new listing or previous listing from 7.0.4, this happens if i paste text, or add the text manually i dont have the option to scroll, the text is there but I’m unable to get to it. has any one else had this problem, it only seems to affect editor mode with convert styled text to html enabled.
I am using OS 10.12.6 and GS version 7.0.11.
ilja
February 7, 2018, 12:29pm
#2
Can you please give this special version a try and see if it fixes the scrolling problem:
http://downloads.iwascoding.com/downloads/GarageSale_7_2018-02-07.dmg
dmboxon
February 7, 2018, 1:18pm
#3
That worked, the issue is resolved. Thank you!
ilja
February 7, 2018, 2:28pm
#4
Thanks for getting back. Seems we need to release version 7.0.12 so everybody gets this fix…
system
Closed
February 17, 2018, 2:28pm
#5
